Originally Posted by
More Power
So Casey... What are the details on the wheels and tires you have on your Tahoe? Thx.
I am running BFG K02 All Terrain tires in size 285/75R16. IMHO, one of the best tires ever made. Long lasting (I got nearly 70K miles out of my last set), great grip in all weather scenarios, and they look great. The only issue is the price has gotten a bit high as of late, so if I were replacing tires today, I would take a hard look at any of the many hybrid tires available (basically a cross between the All Terrain and Mud Terrain styles).
The 33" tires fit my stock rig, but I did crank the front torsion bars just a little and had to trim the lower plastic air dam a bit to keep from rubbing.
As for the wheels, those are OEM "Steely" Toyota rims! A buddy of mine is a Toyota aficionado and sold me the rims many years ago. I understand they are actually kind of hard to get, but I have a complete set of 5 so even the spare matches. Same bolt pattern as Chevy 6 lug, but they are not hub centric. They were originally painted gunmetal gray, but since they were scuffed up pretty bad, I painted them flat black. Recently I painted a metallic silver lip around the edge to dress them up.
