Originally Posted by
strykerAKAmack
Hi All
Truck been running fine up till few weeks ago .
It always went down the road 1800rpm at 65mph .
Started to intermediately jump up to 2200rpm at 65mph then drop back to
1800 . Thought it was trans and was about pint low topped off and seemed fine
Since then truck was hard to start twice . today 3rd time hard start .
On way back home 200 yards from driveway engine surged to 4k then died .
was able to coast to driveway and get it off of road dead.
It does the run and surge then dies in less than minute
It first threw code p0216 cleared that tried to start again .It ran little longer surging and lots black smoke .checked codes again this time p0251 came up by itself .
So its way to hot to do anything with it right now So...
Does it sound like the IP is shot and needs replacing or as looking in book , the timing is off and just needs a tweek {though it says needs to be running to set ??? }
Too Big job to do at home ? Send to shop to fix ?
320k on motor. yank it and put rebuild in it ?
Body is is great shape and AC is ice cold would hate to let it go .
So what would you do ?
Thanks Ed
Have you tried replacing the PMD/FSD yet? Is your FSD on the pump or remote mounted?
Sounds like FSD problems to me.
