Long Story, but here goes.....
I purchased a 1997 GMC 2500 6.5 TD new. My dealer warrantied the fuel pump at 72,000 miles in July 2000. The truck now has 146,000 miles. The current driver of the vehicle had been driving with a failed electric pump for about 6 months. He was experiencing intermittant stalling which I attributed to the failed lift pump. We replaced the pump and he continued to report intermittant stalling that was getting progressively worse. About 1 week ago the truck died completely....crank, no start.
When the hood was opened, the smell of burned electrical something was evident. The only obvious thing I noticed was a blown fuel solenoid fuse. Replaced fuse, turned key....poof! Okay, so it appears we have an electrical problem. Brought in an acquaintance with a bit of 6.5 experience....he figured FSD, so we tow the truck to our shop. Hook up the computer and yep, fuel solenoid driver. Okay, no problem...we tear it apart and run down to the local Stanadyne dealer who happens to have the parts in stock. Now, as we removed the FSD, we noticed that the wiring harness plug was MELTED. I mean, beyond recognition, the resistor is gone!. Anyway, Stanadyne sells us the parts and then proceeds to tell us that there is no way we are smart enough to install the parts and make it run (so much for future business with those guys). So, we install new FSD, replace everything and diagnose with the computer.....no codes. We try to start....and try.....and try.....and disconnect injector lines...no fuel. So, we remove everything and pull the pump and take it to a nicer Stanadyne dealer. He diagnoses and finds that pretty much everything electrical on the pump is burned..Including the fuel solenoid itself. Now he repairs pump no problem....BUT....he is warning me that this is the most severe electrical problem he has ever seen with a 6.5 pump and he is cautioning that there could be additional wiring problems that need to be addressed to avoid frying all my expensive new parts.
So now the questions:
* Has anyone had an FSD fail with severe melting of the wiring plug?
* What is the correct resistor for a '97 6.5 in a GMC 2500 4x4? And does it really matter?
* How many amps does the Fuel Solenoid circuit need to operate? Can I install a smaller fuse to test start?
* Is there any particular section of the wiring harness that I should check for damage?
Any comments or thoughts would be appreciated!
Alan--completely demoralized by diesel pickups
