One of my best friends is a GM World Certified mechanic and owns a Duramax himself. He replaced the turbo on his truck recently. According to him, it's not too bad of a job if you remove the cab first! Of course, having access to a lift and the correct tools makes a world of difference. He says he can remove the cab in just a few hours, and always removes the cab for turbo replacements or head gasket replacements.
