Results 1 to 6 of 6
Thread: Crank, no start except with starter fluid
    Jul 2024
    USA, PA
    Default Crank, no start except with starter fluid
    Hi, all. Apologies if this has been covered but my thread search didn't catch it. The 6.5 in my sig has had intermittent trouble starting lately. Today I cranked it several times with no luck. In the 80's outside, good battery voltage, cranking fast enough, could hear the lift pump running while waiting to start, good flow with the fuel T valve open (both with the terminals in the relay block jumpered and with the relay installed), had been driven about 1.5 hours earlier, plenty of fuel in the tank. Right after I gave it a couple of squirts of starter fluid, it fired right up and ran just fine all the way home - no stalling, no stuttering/hesitating, normal smooth acceleration. Turned it off and then fired right up a couple of minutes later. Before I start tearing into it, any clear avenues to pursue? Many thanks in advance.
    1997 6.5 K2500 Suburban, stock except for relocated PMD (grill)
    Welcome aboard!
    First off, don't use "starter fluid", ever, outside an actual emergency (about to be run down by zombies or the wife/significant other is going into labor). It likely killed whatever was left of your glow plugs, among other bad possibilities. When your truck was new, it had a sticker under the hood that warned bad things would happen if you did. The original issue was likely related to the glow plug controller/relay, or possibly a fuse. Many 6.5's don't like to start warm without the plugs working well. Hot, like shortly after a shutdown, it hot, and will usually start just fine. Cool off for a bit, and no go. Dump the ether and work the problem. Check that all the plugs have continuity to ground, and they are all getting 12V when you turn the key, before, during and after the starter does it's thing. Pull the plugs you can reach and test them. Put 12V to them for a few seconds. They should "glow", hence the name. They'll also burn the hair off the devil's butt, so be careful about that.
    Ditto what Maverick stated above. Sounds like a glow plug issue to me.
    Just an added perk.
    The RH side plugs are not hard to get to... Jack up the RH front place safety blocking/jack stand
    Remove RH tire/wheel.
    Carefully remove the retainer buttons on the rubber inner fender flap.
    First 3 glow plugs are staring at you.....#8 is a pain and must be accessed from under the rig.
    Leaving one dead one is no biggy things will be fine.
    Use 60G plugs ....These are far better than any of the earlier ones.....
    Sit on a box and go at replacing the plugs
    Could be a bad glow controller.
    Have a helper operate the ignition key while you check voltage at the plugs.
    With wait to start light on you should see battery voltage at the plugs.
    Another possibility....The late model 6.5 had a glow inhibit built into the glow controller.
    Before we tear into things....Use a jumper that can jump the large terminals on the glow plug relay (Manually apply 12 volts to the plugs) Apply voltage to the plugs and have your helper hit the starter 15 seconds on the plugs should be enough......
    The glow plug controller should click when the key is turned on...If it is silent...Not good.....
    Check it out
    Good luck
    Jul 2024
    USA, PA
    Thanks for the help, and sorry for the delay - I got swamped with other stuff. I should've checked for codes before I disconnected the batteries to check if they could hold a charge and pass a load test individually. I'm going after the glow plugs as soon as I have a chance.
    Keep us in the loop
    I fully understand about "The other stuff"
  1. Crank but no start
    By 2001gmc36 in forum Duramax 6600
    Last Post: 05-31-2019, 12:56
  2. 02. Crank no start.
    By Flomax in forum Duramax 6600
    Last Post: 12-14-2018, 20:11
  3. 6.2 Crank no start
    By BadDog in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-04-2012, 13:04
  4. Slow Starter Crank but Starts
    By DA BIG ONE in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-08-2006, 15:02
  5. Starter fluid smell under the hood and through the AC in the cab
    By Huntgfish in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-24-2004, 17:15
