Thread: How does this hose come off?
    Dec 2005
    Klamath falls/keno Oregon
    Default How does this hose come off?
    I believe it’s one of two lines going into the heater core.
    And it has a leak..and is it serviceable?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    427,300 miles and counting..
    The hoses attach to plastic quick connectors at the firewall. They can crack and leak. You'll need the tool to disengage the connector from the core inlet/outlet. They're inexpensive plastic sleeves available as a set, or by the individual size (Harbor Freight or parts store items). There may be a repair connector available, or the hose as an assembly. We replaced one quick connector on my son's 2007 Classic 1/2 ton about a year ago. One hose was clamped to the connector, while the other was a hose assembly, bonded to the connector. The failed connector was the clamped one. I don't know if the other can be replaced with a clamped connector or if the hose requires replacement as an assembly, although it looks like a clamped connector would work. The replacement was simple with minimal coolant loss (less than what was leaking), but access is tight.
    Dec 2005
    thanks...
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Leaking Hose?
    By moss6 in forum Duramax 6600
    Last Post: 08-19-2008, 19:49
  2. Hose ?
    By DMAX-HD in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-20-2007, 15:54
  3. I Think I Hose My Crank
    By mhartsel in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-09-2007, 00:25
  4. Need A/C hose from 80's Suburban
    By bmiszuk in forum TDP Classified ad forum
    Last Post: 04-29-2006, 15:27
  5. 01 AC Hose
    By BlackMax in forum Duramax 6600
    Last Post: 07-01-2003, 15:02
