Originally Posted by
Newty
Hey to tdp new to the forum thing so bear with me had some question to my cold starting in the moring so i pull one of my glow plugs out to see witch number I have thinking maby a 7 or 12g and I have a ac plug but it has nothing matching the normal list I have ac delco 0 100 271 107 10.5v 843 under the threads of my glow plug anybody have a brake down for this ? Thanks
DmaxMaverick
Normally, a thorough flogging is in order.
The same flogging is generally used for run-on sentences, as well.
But, yes, AC Delco 60g's are generally standard practice for replacements.
Do you know how to test plugs for "general" health?
EDIT: Oh, I did a couple quick google searches for the numbers you posted. Some of the results seem to indicate that they might be 60g's, others say no. But, you gotta take all that with a grain of salt since you never quite know what to expect on the internet. Best bet might be to call a local GM dealer.
