Is anybody doing this? I am researching the possibilities/benefits of this idea adn would love to hear users comments.
Bill Heath has one- there was a thread on this last week.
Thanks. I read that post but thought that maybe we could get some folks who actually use a system to report [img]smile.gif[/img]
hI, Ive had Bills water system on my truck for about a year now, With flawless
results. He also installed his heavy duty fan clutch, With the two add ons I no longer see high water temps as well as trans temps, and exhaust. I often run a little methynol with the water for that extra kick in the pants. i wish i had got it sooner. I never have to down shift and slow down due to heat. The Tcc stays locked up because of the extra power.ALL
IS GOOD....
JIM
94 K3500 Blue dually<br />Heath-H/O chip<br />4\" exhaust<br />amsoil bypass filters (oil)<br />AfE air filter<br />4L80E-W- trans control<br />water inj. thanks bill heath<br />hayden severe duty fan clutch<br />all gauges<br />One Bad Bowtie
Thanks for posting Jim. Good to hear your report. I spoke with Jamine at Avant yesterday and we chatted about Bills mist system too and he thought it was pretty good. I guess Bill took him for a spin at the last ronde and he saw it work in action.
I'm leaning towards it pretty heavy vs an air to air or liquid to air intercooler but still have a bunch of questions.
Do you have an intake temp gauge?
If so, how much will it drop the intake temps?
Do you use distilled water, tap water or washer fluid?
How big of a tank do you have for the fluid?
Where did you mount it?
Do you tow?
If so, how much water do you use per hour with what kind of load?
At what boost level do you have yours set to come on at?
And the big one... Under load, do you notice a big increase in HP when you switch it on?
Thanks!
Ken
Hi Ken, I"D Love to answer your ?s I have an intake temp gauge ordered thru bill
heath, He demonstrated the big change in temp for me and got me wanting a gauge.
you can pull a good hill for say a mile, touch the intake and you'll leave skin on it, with the same pull with the water on you can put your hand on the intake and leave it there.I run a 12 gal steel air tank mounted in the rear of my pickup, powered by an rv water pump, I use tap water ran thru a rv filter, I pull a 30'
fifth whl. truck and trl 14,000#.. In theory if you were to pull steady for an hour straight i would use the 12 gals. but thats not going to happen, I pull the trailer 300 mi stop to fuel an fill the water at the same time it's not that big of a deal, all truck stops have water at the pumps,as far as seeing the power ,if i'm pulling a 6% grade at 45 mph no more throttle , and turn onthe system it will be up to 60 in maybe a minute, it dosent take long to respond especially if i'm running methynol it may take 30 seconds
I hope i answered all your ?s if not . don't hesitate to ask
Thanks Jim! You answered a bunch of my questions and it really matters that you actually USE your truck. I've been to WA and know you have some pretty good grades to really use it on.
How many miles have you towed with it so far? It really sounds like the way to go for me too.
How much did the whole system cost? Sounds liek you are pretty pleased with it. Is the system pretty easy for a mechanically inclined person to install themselves?
Ken
Hey Ken, Sorry for not answering right away, I took the trailer up to the lake for the last days of trout, and caught a
mess of fish, I guess i forgot one question you had about when the system comes on. I cant think of who makes the switch, you would have to talk to Mr. Bill,I have a 10# switch, So i also have an on/off switch when the power switch is on the system is armed and when i reach
10# boost the water comes on and i have a turbo master that allows me 16# max boost
it's really straight forward, theres also a valve coming from the resiovior that limits how much water is deliverd, i dont think you'll have any problams bill health will he;lp with parts and install
over the phone he's one of the good guys
i put that system in the same timechevy put a new pump in my truck, so i know i've put 12,000mi no troubles yet.I think you'll like it also.
What does this do for your milage?
mileage is allways on my mind, before the water was installed i would get 12 to 15mph whether i wanted to or not pulling my fifth wheel depending where i went , More or less hills.
now i average 15 all the time while using the system. Especially if i use mythanol-w- the water
I even use it empty on the long big hills,You can feel the difference at that time. the pedal needs to be applied for more power on the hill,I'll turn on the water and watch the speedo go up. My one ton has allways got good mileage 18 to 20, so i see 20 all the time. I can't complain. Everything done to my truck has been done by Bill heath, from chip, exhaust, to water
he's got it tuned just right,turbo master, fsd cooler,his own design.it just gets down the road and does it efficeintly..
Jim,
That's about the same mileage increase I've heard from another guy too. Do you use washer fluid for more power and/or freeze protection or do you just add the methanol yourself?
I've been watching the boost on my truck pretty closely since I've been researching this unit. What I've found is that quite often my boost is under 10 psi for a while until I get the rpms up to about 2000. I'm wondering if intake temps will get overly hot at boost levels under 10 psi when under a heavy load. Got any idea? If so, I guess a slight change in driving habits will be required. Is this why you are getting an intake gauge?
I called Bill and he was sure easy to talk with about this system. I guess calling this mist injection is not really right. It sounds like it injects a stream, not a mist, BEFORE the turbo. The wind velocity and heat then atomizes the water. The system sounds very simple and well built.
Ken
HI Ken, I use methanol myself, I really have'nt
heard about using washer fluid, that would defenetly be cheaper in the winter.
To increase your boost, you'll need to get a turbo master,You do have a pyro? more boost =more power, and heat,Thus the water system, before the water my boost leval was 12# max, I was using bills H/o towing chip.
and i had to slow down on a lot of hills,Because of the heat, {exhaust temps}.now when i'm pulling hard i see 15 # of boost and 1000deg on the pyro,that's why i want an intake temp gauge
it also lets you see the results of the water, and you can make adjustments to flow rates.
I'm glad you talked to Bill, He will explain every thing in lamens terms and explain it until he's sure you understand, the man has the patients of an oyster.
Jim,
So the water increased your boost from 12 to 15 psi? Sounding better all the time. I better start saving my pennies!
What's the downside in your opinion?
Is it injected before or after the turbo?
Ken
[ 11-04-2003, 01:23 PM: Message edited by: The Buffalo Guy ]
Hey Ken, In my opinion the only down side ,If you can call it a down side, is that i only have a 12 gallon tank for supply, I allready have a change in place this spring, I've bought a water
bladder from camping world that fits just right under my tool box, It holds 30 gals. so i won't have to worry about one less thing.
To answer your other ?.Bill tested two locations.
directly in the intake manifold,post turbo. It worked fine but it was alot harder to adjust volume, so it is now pre turbo, And in my opinion it works flawlessly, post turbo was tricky, it was still ran by a boost switch, But if the intake temps were low, for instance, from a stop and flat land driving, If the system was armed with low intake temps. When the water was injected it would cause the engine to over fuel if you will. Sometimes leaving a trail of steam
pre turbo stoped this problam.Now it's steam before it's in the engine. "Mist injection"
Jim,
Any concern about turbo damage with it being injected pre-turbo?
Ken
What can you put in it (except alcohol) to keep it from freezing?
James,
From what I hear folks are doing you can add methanol or just use windsheild washer fluid which is water and methanol. The methanol also gives added hp.
Bill Heath told me that while on the dyno he showed an added rear wheel HP gain of 60 HP when he flipped the switch to water (only) injection!
60 rwhp is a huge gain for a maybe 180 rwhp motor. Of course, this is the manufacturer dispensing the numbers here but he has always seemed to be a straight shooter and has a good rep. with the guys using his system.
I agree that a front mounted simple intercooler would be the best but I have some serious resevations about it namely:
1. Cost. $1300 is big bucks.
2. Location of the unit is very troublesome. Hit a coyote or rabbit and that's it. Also, living on gravel roads as I do would be too much for it. I'm sure it wouldn't take long to get a hole in it. My front grill is a testamant to the pounding gravel roads give the front end.
3. The location also seems to be lacking good airflow.
4. The trait of the 6.5 to weep a little oil into the intake would greatly reduce the effeciency of the unit as it coats the intercooler. An oil trap should be added to recycle this oil and keep the unit clean.
With all that said, I know there are plenty of guys who are very pleased with their intercooler. I just feel that this water injection needs a very close look as it seems to have some benefits over a standard intecooler namely:
1. Much greater added hp.
2. A cleaning effect on the motor.
3. No need for forward speed or air flow. (which is nice on hot days with tail winds)
4. Water injection also cools the whole turbo housing which should increase longevity.
5. Increased, not decreased, turbo boost.
6. Cooler intake temps.
Since I don't have a system installed yet these points are just from my research but this is where I am to date.
Ken
Let me dispel a few myths...
Cost is high, but it has been well worth it for me.Originally posted by The Buffalo Guy:
The construction of the unit is much more robust than what you are used to looking at with a radiator. It would take a very large rock at very high velocity to put a hole in it. I live on a gravel road, too. A rabbit or coyote would probably not damage much at all. Once you cleaned the hair and guts out of the fins, it would probably be back to full functionality. One guy posted on here last year (the post is now lost due to the "glitch") that he dropped the front end into a ditch and rammed the intercooler into the opposite bank. He hosed the mud out and found no damage.Originally posted by The Buffalo Guy:
The large intercooler kit comes with a rubber deflector flap that does a very good job of providing good ram air flow. My truck has responded very well to the intercooler during mountain climbs.Originally posted by The Buffalo Guy:
All turbo charged engines tend to do this. If you read any of the popular books on turbocharging, they all stress the need for periodic cleaning of the intercooler core internal passages. These books were written for gasoline engines. The intercooler is quite easy to remove for cleaning and it has two drain plugs.Originally posted by The Buffalo Guy:
Also, keep in mind that the volume of water (or water/alcohol) is taking up space that could be occupied by air. As I just towed to Las Vegas and back, it's hard for me to imagine hauling a big enough water tank to allow me to run the way I did on this trip. On Friday, November 7, 2003 I started driving in Las Vegas and stopped for some sleep at Colby, KS...994 miles later. I stopped for fuel four times...128 gallons worth. I was running at 75 mph for most of that time (except when slowed by curvy roads and high mountains). Most of that time I was running with boost pressure above 10 psi...often 13-14 psi. I don't know what mixture is used, but that would be a lot of water. If you run out, slow down because things heat up and power is gone.
For fairness, I'm not really against the water injection idea. I've been around its use in aircraft for a long time. However, those applications were for short time periods (takeoff) and not for cruise conditions. I just think it is being over sold a little and some misinformation is being spread about the intercooler application. I want to keep the discussion fair and balanced.
Also, I have refrained from commenting in this thread because you were specifically asking for input from people who used water injection. However, I believe it appropriate to chime in now because of my experience with the intercooler. Most of the concerns you have listed are not valid and will bias your decision...if you've not already made up your mind.
[ 11-11-2003, 06:52 AM: Message edited by: ronniejoe ]
My problem with the intercooler is the location.. can't see how you would get any airflow on my truck due to the skid plate. It
extends from in front of the rad to about the middle of the oil pan. I also noted on last oil change a deep gouge right down the middle of the skid plate, probably from hitting a boulder. I seriously doubt the intercooler would have survived. If I could find one that mounts just behind the grill, would seriously consider it.
K.D.
Ronniejoe:
My consideration of mist injection is based soley on cost vs benefit. I have never been out west, and if I do go, it will be a one time thing. I do go to Florida 3-4 times a year, where my biggest towing challange is Jellico mountain. Last trip, my highest EGT's were around 900 deg, post turbo, barely in the yellow, and then only for a short period of time. My speed goal is to keep the truck from downshifting, which it now does pretty well. I have added a new downpipe since then. I can install the mist injection myself, with a cost of approximately $500. An intercooler costs $1,300 for parts and at least $200 for labor to install it. I know it would be difficult to get someone local to install it. I could justify $500 for the purpose of potential engine longevity. But on an engine that already has 150,000 miles, it is hard to justify $1,500. For me, the question is not a choice between an intercooler or mist injection, but mist injection or nothing. If I do get it, the only reason would be to make the engine last to the magic 300,000 miles. I don't want to do anything that is going to negatively effect the reliability of the turbo or other engine component. I don't believe using alcohol for antifreeze fits my use criteria, but I could use pink pop antifreeze or something else if need be, or I could use it in summer only. Based on these parameters, yea or nea?
