Originally Posted by
SoTxPollock
2002 Chevy Silverado LTCC, SB,
Added Racor RS60s filtration post OEM, at 20,000 miles.
Original injectors, 132,000 miles, they're not as quite as they used to be, but still run great.
Never had any kind of problems, starting, running etc. Love that truck.
ROI, supposedly the filtration is down to about 2 microns so I don't expect any problems from particle errosion. I'm sure this has already saved GM some money on replacement of the injectors, next year come July it will be my nickle if they go bad. I jus think its an investment in assurance of continued top performance. I've always maintained my vehicles like I was going to walk out of the house in the morning and drive straight to New York without haveing to check anything first.
Side note: By the way JBPLOCK, you said SWR said the wear was 6 to 7mm size, that's not millimeters obvously, you ment microns right?
UPDATE FOR 2010-Had to do 8 new injectors at 160,000 miles on my nickle, waited too long go get in on the warranty. Truck runs better than it did when new, actually idles smooth now, it never did before. I suspect I may have had a bad injector right from the start at idle and never knew it since it was my first diesel, I also suspect that by the time 20,000 miles went by without additional filtration it was on the way to failure before I got the additional filter installed.
I suspect the mileage will drop a little from the original, but there's no scientific way to blame it on the injectors because of the ULSD which was not available during the first couple of years of the truck's life. I still love it. I would recommend extra filtration to anyone who like me wants to keep the truck for a long time.
