NP 246 AutoTrac
Originally Posted by
DmaxMaverick
How many TC's do you want to buy? Bad advice. Autotrac II fluid IS NOT just blue Dexron. The Autotrac TC's have unique requirements of the fluid. Unlike traditional TC's, they have active syncro's and slipper clutch friction surfaces. Some premium synthetic ATF's claim to be compatible with Autotrac II fluid, but most do not. Put Dexron in your Autotrac if you want, but don't advise others to do the same unless you are offering a warranty with the advice.
DM, I had replaced my NP 246 AutoTrac w/new unit. I was informed that I can use full synthetic by seller, not being sure I contacted the manufacture of the unit and an engineer confirmed it was ok to use the synthetic fluid. Nowhere in the packaging was there any reference to any special fluids like Autotrac II just reminder to make sure to fill unit.
I have wondered about the clutches needing some friction inhibitors but now after your post I'm concerned about the synthetic fluid I'm running, am I asking for trouble, or?
