THAT STALLING PROBLEM IS ONE OF THE THINGS THAT HAPPENS WHEN THE DS4 SOLENOID DRIVER STARTS TO FAIL. THAT'S WHAT MY TRUCK WAS DOING AND REPLACING THE DRIVER FIXED THE PROBLEM. CHECK AND SEE IF YOU ARE GETTING A CODE 35. THIS PROBLEM HAS BEEN DISCUSSED QUITE A BIT ON THIS FORUM. CHECK THEM OUT
1995 K-2500HD,6.5TD,EXT. CAB, LONG BOX,AUTO. TRANS,UPGRADES INCLUDE: AFE AIR FILTER,3\" EXHAUST FROM TURBO,HAYDEN SEVERE-DUTY FAN DRIVE,MAX-E TORK E-PROM 2.0,PMD ISOLATOR,TURBO MASTER BOOST CONTROLLER,PYRO & BOOST GAUGES
