2500HD/3500 Trucks, Transmissions & Drivetrain
Originally Posted by
dmaxalliTech
Unfortunatly, its not unheard off. It appears to be a quite common problem that plagues the magnesium case units found pretty much from 1998 and up on most GM trucks.
The problem is as simple as 2.00 clip breaking.
The clip holds the pump in the case from much movement and when it breaks, the pump is free to move and eventually wears a hole in the case causing the leak. If it goes to far, the leak can drain the case and you may never even know it, at this point, its usually beyond repair.
There is a fix for this problem though.
dmaxalliTech,
Can you tell us, what is the fix, does all the shops do it, & how pricy is it?
chipper 2001 GMC,,D/MAX,SLE,EXT CAB,LONGBED,LINEX,FIRESTONE AIR BAGS,,driv\'en it & smilling, 32' Excel 5er
