Results 1 to 20 of 32
Thread: 6.2/6.5 Diesel Conversions - The High Points
    Arrow 6.2/6.5 Diesel Conversions - The High Points
    By Jim Bigley
    A few key points to remember:
    1. The GM 6.2L and 6.5L diesel engines share the very same bellhousing configuration and bolt pattern with all Chevy and GMC V-8 gasoline engines (till the LS series of gas engines).
    2. The GM 6.2L and 6.5L diesel engines share the very same motor mount configuration with all Chevy and GMC V-8 gasoline engines (till the LS series of gas engines).
    3. The GM 6.2L and 6.5L diesel engines are about 200 or so lbs heavier than a gasoline 350 V-8. The bare longblock weighs just over 700 lbs.
    4. The GM 6.2L and 6.5L diesel engines have identical dimensions, and nearly every bolt-on component on either engine will interchange with the other.
    5. A conversion from gas to diesel will require a hydraulic brake booster, diesel starter, larger diesel radiator, all engine driven accessory brackets, and fan assemblies. Your A/C compressor and power steering pump might work with the correct diesel brackets.
    6. The automatic transmission torque converter should be changed to one rated for diesel operation. The stall rpm of a gas converter will be above the 1700-2000 rpm torque peak of the diesel. We suggest modifying the transmission governor setting to upshift at an rpm below the engine's governed rpm of 3300-3600 (if non-electronic transmission). An overdrive transmission is recommended. Low gearing, no overdrive and higher freeway speeds make the diesel engine hard to live with. Best fuel economy is possible when running the engine at about 1800-2000 rpm at your chosen cruise speed.
    For anyone considering a swap, I'd recommend buying a diesel donor vehicle, swap all the parts in both directions, then sell the donor. This will result in the best and least expensive conversion. Buying all the diesel-related components usually puts the cost out of reach for most people. Older diesel trucks and Suburbans with body or other cosmetic problems are usually pretty affordable. TDP
    Copyright 2007 by The Diesel Page
    Default conversion
    would a diesel van make an ok donor for an 83 k10 gas to diesel swap, or should it really be a truck or suburban? if the van is cheap enough, I can still buy some of the diesel parts new and still make the project reasonable. thoughts? thanks.
    Jun 2008
    So IN.
    anything new to add ??
    Question
    I have a towing special suburban I am going to swap a diesel into. My question is can I use the stock radiator? I know the diesel needs a better one then gas but the towing special has a better radiator for bigger loads. Would this work for the diesel or would it still not be enough.
    Jun 2008
    So IN.
    Quote Originally Posted by stuntdoublejoe View Post
    if it was mine i'd try it,,,but know where to get a upgrade if it didn't cut it
    What problems would I come across using the turbo 400. I don't go on the highway much so not having an overdrive isn't much of a problem, and I've heard it runs on a vacuum and if thats true how much would a vacuum pump cost? Also how would I go about changing the governor for the diesel
    The van diesel engine and various other components would work for a pickup or Suburban installation. There may be a couple minor items that'll need to be changed, but overall, most accessory items would work fine. For example the oil dipstick, oil fill pipe, throttle & cruise cables are different between the two applications.
    The gas big-block equipped Suburbans and trucks received the same larger radiator as the diesel - at least they were the same physical size, so I'd try it. If the Suburban was equipped with a 350 gas, it'll need another radiator.
    A non-OD automatic worked just fine back in the days of the 55-mph speed limits - the first 9 years of my GM diesel experience was during the days of 55.... Nowadays, you just can't comfortably run at freeway speeds without an OD. Plus, when I upgraded to an OD automatic, I saw an immediate 6-mpg increase.
    GM produced vacuum pumps and a VRV (Vacuum Regulator Valve), that was bolted to the side of the fuel injection pump, to simulate manifold vacuum on a gas engine. The VRV allowed a TH400 (or TH350) to function and shift normally behind a 6.2 diesel.
    How much would a vacuum pump and VRV cost me? I can get a 700r4 or a 4L80 for about $500. Would this be a better option because I am on a very tight budget and already have the engine and brake booster.
    The 700R4 can be built to shift without electric/electronic control - that's what I did for my 6.2L diesel. Still, the 700 would require a throttle-valve (TV) cable and bracket. A 4L80-E would require a TCM, harness, engine speed sensor and TPS (figure about $1k beyond the cost of the trans).
    If on a tight budget, and if you wanted to use a TH400, you could post an ad in the classified ad section for a VRV/vac pump. Buying used would be less expensive than new.
    Apr 2004
    Ottawa, Ontario
    Jim:
    What method did you use for locking up the 700? When I was building the Buick, the only thing that was available would only give me lock up in fourth. As I tow with the car, it is important that I have lock up in third. Currently use a switch on the dash that does work but would love to find a way to do it without having to remember to work the switch.
    Bill
    94 Cadillac Fleetwood (sold)
    08 Aerolight 23TT
    I now have the VRV/Vac Pump, so now my question is how do I change up the governor and shift points?
    [URL="http://www.andysautosport.com"]
    Andy's Auto Sport[/URL]
    what about a 5 speed i noticed diesels clutches are all different numbers from gas motors, even when they dont have the dual mass flywheel, is there anyway to reuse a gas clutch/flywheel? are the crankshaft patterns the same where your flywheel/flexplate bolts on?
    Quote Originally Posted by kyle41005 View Post
    The diesel flywheels, clutches and pressure plates are specific to the diesels. Gas versions won't work.
    Default swapped 454 for 6.2
    i cant seem to get it started now that its in my one ton
    finally got it runnin but its kinda rigged.i still need to find the power steering brackets.
    the clutchpak off 454 is the same as 6.2.the flywheel is different but the clutchpak is the same part number.at least thy are on a 4 spd
    Nov 2011
    Walker Lake, Nevada
    Default C ya
    are one and two peice rear mains the same as far as the flywheel
    mark
    Quote Originally Posted by duallyman30 View Post
    The clutch disc used with the dual-mass diesel flywheel does not have any internal springs or dampers. The clutch disc used with the newer single-mass diesel flywheel incorporates a series of springs/dampers.
    So.... you have to be sure what flywheel you have before ordering/installing a replacement clutch disc.
    mark
    The same flywheel/flexplate can be used on either rear main seal engine.
    Oct 2012
    Ohio
    I have a 1990 Chevy K2500 with a 6.5 V8 Turbo Diesel in it. I was woundering what kind of motor(s) I could swap out and also what else I would have to swap for the gas motor. And could I keep the turbo for the gas.
    Hi
    Any GM truck engine will fit,250 6cly,283-400 small block,or 454 big block.
    You will have to go to a carb and distributor.Unless you want to swap in the wiring harness from a gas truck of the same vintage.If you have an auto trans you will have to change the tourge converter.And no you can't keep the turbo from the diesel and use it on the gas.
    You would be further ahead to replace the diesel engine.You say it's a 90?
    If so someone has already replaced the engine,it would have come with a 6.2 mechanical injected,and no turbo.
    Whats wrong with the engine? Lots of help here if you want to fix it.
    Thomas
