6.2's were used from 1982 till 1993 or 94 in GM trucks and vans. They can be found used for pretty cheap. They are easy to work on. No computers required, note the 1 wire I mentioned in my post.
These engines were also used in Humvee's (H1's to the general public) for a long time. Parts are still plentiful.
I'd search craigslist or here for a good old complete truck and use as much of it as possible to build yours. It's cheaper that way than buying all the parts, unless you get some steals.
Just make sure it works good before the swap. I pulled a 6.2 out of a Burb that had been recovered from a theft almost 9 months earlier and left to rot. It ran great when I put it in my much nicer Burb body and it's 700R4 worked well too. It ran five months (many times idling for hours a day during -40's and -50's in Alaska) before I spun a bearing. Looking back, it could've been easily fixed with a new crank and bearings, but I pulled it and started to rebuild it when I came across a much nicer Body and went to that one, which ended up being a money pit.
Look around here, this site was started originally with the 6.2's in mind. LOTS OF INFO!!!
Have fun with the swap, you'll have a very unique truck by the time you get your license.
