Thread: Oil Pressure issue?
    Mar 2024
    aurora indiana
    Default Oil Pressure issue?
    Good evening folks, my first post related to my first Duramax engine.
    Information:
    2007 2500HD with the duramax engine
    6.6L engine says it on top of engine cover
    Original 26,000 miles on it
    On my way home I notice the oil pressure was low I think but don't know?
    Cold start 50/55PSI
    warm idle 30PSI
    30-60mph 35PSI
    60-70mph 35-40PSI
    80mph 40PSI
    Current history:
    The oil needs to be changed, the truck sat for months at a time only used in summer to pull large camper.
    Any advice related to proper oil pressure will be really appreciated. One last question, what brand oil and filter is a good one to stay with?
    Thanks to all, Steve
    Dec 2005
    Klamath falls/keno Oregon
    sounds Ok to me...I use ACdelco filters and Amzoil..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Knoxville,Tennessee
    Ive got an 06 been using Donaldson filters and CostCo oil.
    -Patrick Henry
    A5150nut
    2006 K3500 D/A
    94 6.5 4x4 5spd Sold
    Feb 2003
    RAYMOND WA.
    217,000 miles, i have always used ac delco oil filters and delo 400 sde, isosyn advanced oil, sae 16w-40.
    ORDERED 1-15-03 ARRIVED 2-10-03= 03/2500HD/D/A/EXT.CAB LT/ LONG BOX/4X4/CARBON METALLIC/ONSTAR/ TTT CAMPER MIRRORS/WESTIN BOARDS WITH LITES/HUSKY FLOOR LINERS/PRO FIT FLAPS/ACCESS TONNO/LINEX BED RAILS/ FUMOTO OIL DRAIN VALVE,
    BEDRUG/BILSTEIN SHOCKS/ ISSPRO EGT GAUGE/RED LINE LUBE, BANKS EXHAUST BRAKE. GALAXY 929 CB/ WILSON 1000.KENNEDY LIFT PUMP.
  1. Big problem, large oil loss and lost oil pressure
    By jf-schaack in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-04-2010, 20:33
  2. No Oil Pressure After Oil Change (long post explaining my proceeder.)
    By wthif in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-02-2006, 05:47
  3. Oil Temp/Oil Pressure guage installation?
    By Steve O. in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-12-2005, 10:38
  4. OIL TEMP GOING UP TO 220 AND OIL PRESSURE LOW, -20 outside
    By Petrella in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-14-2004, 09:24
  5. UPDATE: Oil Loss, Line Fixed, LOW OIL PRESSURE
    By EscaladeDiesel in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-12-2003, 20:24
