Has any one come across, a power steering leak in your 6.5 ?
Lines do burst, their is a cooler for the p/s as well....
1993 Chevy K3500
like us on Facebook
Shaft seal started leaking on my pump. It was only 25 yrs. old. GM crap. No problem to replace the seal if you borrow the tool to pull the pulley from Autozone, etc.
Thanks for your replies!! It looks like the cover rusted thru in three pinholes along the bottom .I was only able to find it with dye, and yellow glasses. Has anyone repaird the cover with epoxy or solder? I tried epoxy along the bottom but the holes keep weeping fluid.
You can try and patch it, I would think a new one would last longer than a patched up rotten pump would...
1993 Chevy K3500
like us on Facebook
You got a pump for a gasser, which has vacuum brake assist and no need for the additional return port. The pumps may or may not be the same otherwise, so I'd be very cautious using it. The pump demand is significantly greater with brake assist and power steering, vs. power steering alone. Unless you can verify the pumps are the same, the replacement you have shouldn't be used, even if it fits perfectly. If they the same, the returns can be Tee'd. However, if it didn't come out of the box with that accommodation, I'd strongly suspect it is simply the wrong pump.
