Results 1 to 12 of 12
Thread: My 93 K2500
    Sep 2014
    Harlingen, Tx. USA
    Default My 93 K2500
    Hello all. I thought I'd post up some pics of my most recent 6.5 truck. Its a 93 K2500 with 160k on it that I traded a lawnmower for about 6 months ago. The engine was taken apart, as it had suffered a blown head gasket. I went threw the engine, giving it a new set of Mahle rings, rod bearings, oil pump, timing chain, gaskets, etc... The cooling system was upgraded with a late 130 gph water pump, 9 blade steel fan, and modded HD fan clutch. A couple months ago the turbo was upgraded to a HX35/40 hybrid with a CKO 14cm turbine housing, and a genuine Holset compressor, and wheel. Then a 31x12x3 intercooler was installed, as well as a Peninsular upper intake. The current DB2 IP has had the fuel screw turned up, and the injectors are new Bosch N/A units. I have an extra injection pump in the shop at the moment being modified for additional fuel, as well as a set of injectors being built with genuine Bosch Germany 311 nozzles, and popped at 2200 psi. The truck has been loads of fun, and while I owned 3 others in the past, I didn't realize how much stronger they could be with a few well selected modifications. While it still has nowhere near the power the newest diesels have, its certainly on par with the earlier D Max's, Cummins, and Powerstrokes. The truck is no beauty queen, but its a great work truck, and pulls a trailer fantastic. Thanks
    I have quite a few pics, so it will take a couple posts to get them all.
    Matt
    1993 K2500, 8600gvwr, 4x4, 6.5 TD (F Code), 4L80E, GU6 3.42, G80 Gov Lock. HX35/40 hybrid Turbo, 31"x12"x3" CAC, Peninsular upper intake, IP turned up 3/8 turn, 130gph water pump, 9 blade steel fan, with modified fan clutch for early engage. Diamond Eye 3" DP, with homemade 4" exhaust.
    Sep 2014
    Harlingen, Tx. USA
    Pics of the engine after paint, and exhaust.
    Matt
    Sep 2014
    Harlingen, Tx. USA
    Pics of the truck.
    Thanks for sharing! Nice looking engine you have there...
    Sep 2014
    Harlingen, Tx. USA
    Pics of the upgraded turbo, intercooler, and Peninsular upper intake.
    I'm sorry, I know this was a bunch of pictures, but thanks for looking.
    Matt
    Sep 2014
    Harlingen, Tx. USA
    Thanks Casey, I appreciate the kind words.
    Matt
    Feb 2003
    Grand Rapids MN 55744
    Howdy
    Looks outstanding!
    Make sure to take to a chassis dyno and let us know what comes up!
    The CAC looks about the same as mine except mine is sitting on the floor...
    Thanks for sharing!
    2001 Chinook RV, V10 gas
    1967 GTO, 1989 Honda Transalp
    3 kids, 1 wife, 1 dog
    Sep 2014
    Harlingen, Tx. USA
    Quote Originally Posted by Dvldog8793 View Post
    Howdy
    Looks outstanding!
    Thanks for sharing!
    Thanks for the encouraging words. My local speed shop (Deleon Racing) has a chassis dyno ($75 for 3 runs), but I would like to have my new hopped up DB2 installed, along with the marine injector before puuting it on the rollers. They don't call those things Heartbreakers for nothing, so I want to be as prepared as possible! 250 would be great, but anything over 220 to the rear, and I'll be content.
    I found a 2009 model (you can actually see the 09 julian date cast into the housing) DB2831 military IP, that I sent off for the royal treatment, and was told it will be pushing as much fuel as can be pushed threw a DB2. Here are a couple pics of the pump before I sent it off for the rework, as well as the Bosch 311 marine nozzles. Thanks
    Matt
    Very nice work. I wish my ’93 looked as good!
    Sep 2014
    Harlingen, Tx. USA
    Thanks, I appreciate it.
    Matt
    Dec 2011
    Henderson, Nevada
    Hi Bowtie,
    Your stuff is just too beautiful to put on the road, work of art. Thanks for the photos !!!!
    Jerry
    1996 Silverado 2500 TD , stock except for a remote mounted PMD.
    I purchased this Truck 7 years ago from the original owner, had 80,000 miles on it. I Had the engine remanufactured at 100,000 by a local remanufacturer that does 6.5 Engines for the Military. Now has 105,00 miles on it.
    Sep 2014
    Harlingen, Tx. USA
    Quote Originally Posted by ginger743 View Post
    Hi Bowtie,
    Jerry
    Thanks Jerry, I really do appreciate the compliments. I know I went a little overboard with the engine detailing, but thats just because I've spent much of my life collecting, and restoring old vintage small engines from the 20's, 30's, 40's, and a few from the 1950's. I have shelves full of them, and I gave my old 6.5 the same treatment. This was a very tight budget build, and no part of this engine went to a machine shop. I honed the cylinders, lapped the valves, and polished the crank myself. I even reused the original pistons after a good cleaning. All it got was rings, rod bearings, oil pump, timing chain (just chain, no new gears). Even the paint was just left overs from an old Wheel Horse Garden Tractor I restored.
    I imagine if I continue adding more power, there will come a day when I'll be forced to upgrade to the stronger Optimizer platform, but until that day, I plan one getting the most out of this 6.5 that I call The Poor Boy Special. Thanks
    Matt
