Used Motor Oil As Fuel
All,
I'm an Electronic 6.5 guy and looking at Waste Motor Oil as a fuel stretcher. My research seems to point to WMO as a better alternative than Waste Vegetable Oil. Any 6.5'er burning any mix of WMO to diesel or even straight up? I understand our optical sensors can present a problem, is there anyway to fool this sensor on the opacity of the fuel.
I believe that filtering WMO down to 5 microns (whole house water filter) and sucking from a catch tank far away from the bottom to avoid water should provide an excellent and safe fuel that could be mixed in the tank with the existing diesel.
I would think the lift pump might be the major issue if we were to go higher than a 50/50 mix as over time the higher viscosity might wear it out. The IP however I believe should be OK at dealing with the blend.
I am game for moving in this direction, many Ford 7.3/7.3 Powerstrokers are running up to 100% WMO in the summer and lower cuts in the winter with no IP issues after many years. I know the optical sensor will give us issues as we increase WMO to ULSD ratio and maybe why I don't read about more 6.5'ers doing this.
All feedback appreciated.
Mark Magee
98 Burb 2500 LT 4x4 VIN G, 4:10's 180K miles, Amsoil Bypass/full flow filters, Turbo Master, Heath ECU Reflash, Duraterm GP's, New Injectors, Walbro FRC-13 LP, 480LE Rebuilt 2X, Vacuum Pump Delete, K&N Filter, Fluid Damper, DTech remote bumper mount PMD, Kennedy Exhaust, Kennedy Fan Clutch, Robertshaw 192F stats, 2.5" Crossover, CAT gutted, Fumoto Drain, Alcoa Centerline Wheels, Ride Rite Airbags.
2013 Keyston Fuzion 301 Toyhauler 9,100#s empty
Velocity XLFG N34XL
Brady Texas Hill Country
