Results 1 to 20 of 116
Thread: Amg P400
    Yessssss indeed, a wretched place to put a cooler I agree.
    I have seen one placed in a custom winch bumper brush guard up front that looked nice and protected the cooler very well.
    The only way it would get hurt would be a direct head on crash.
    The cooler was behind a nice aluminum expanded metal grill to keep rocks off it too.
    Nice job on your truck BTW.
    Anxious to hear the results of your tests.
    best
    Robyn
    Feb 2008
    N.Delta, BC, Canada
    Default What should I call this? An intercooler Grate or Grill?
    Well... I'm nearing the end of my project truck and I'm going to miss wrenching on it.... kind-of. Here are a few pics of the "protection" I put in front of the intercooler.
    The skeleton will hopefully provide protection from a dreaded collision with anything.
    I put a jack under the 3/8" bottom steel plate and it has the strength to hold both front wheels off the ground! The aluminum grill/shield is for rocks. I am heading down 60 km (40 miles) of gravel on Sunday to get to a fishing destination... I wanted protection from the stones.
    Feb 2008
    N.Delta, BC, Canada
    Forgot to mention... the skeleton above is welded between hooks. To remove you unbolt the hooks and 2 more grade 8 bolts on the bottom plate.
    Feb 2008
    N.Delta, BC, Canada
    I installed dual 9" electric "pull" fans... made in Italy. I hooked them up through a relay and manual switch inside the cab.
    The fans will probably only be used when cruising up a long steep grade... but I added them because thats when you need the cooling most!
    The switch on the dash lights up when the fans are rolling!
    Cheers..
    Oct 2003
    Maine
    Please keep me informed of testing with and without the fans. That is a mod i have been contemplating...
    Thumbs up
    Nice work JB. Does your IC sit any lower than the commercial kit IC's?
    The Turbo Tech IC I installed in our 6.5 project back a few years ago didn't sit low enough to be affected by concrete parking lot stops or curb height objects.
    Feb 2008
    N.Delta, BC, Canada
    I pulled a good hill going in and out of Port Alberni during the trip.
    It was a cool day going up the pass on the way in... and the fans kept the engine temp steady.
    It was a record HOT day going back out of the same mountain pass and the fans didn't seem to be a benefit at all. I pegged the manual temp at 240°F(measured just before rad), the dash gauge read 100°C (212°F) in the engine. Ambient outside temp was 36°C (97°F).
    The truck needs more fuel. No black smoke up the climbs, the pyro read 600°F max. I'll get the IP bumped up more and dyno it at the same time.
    Jim.. I'll measure the height on the IC skid plate... it looks to be 9 inches off the ground... a touch lower than the cross member. I am going to weld a lip on the front of it to prevent scooping snow in the winter
