I appreciate the info. I read previously and can see how important that front bracket is. It's actually pretty easy to get at from the wheel well.
Since I just replaced the tank & fuel lines also, is the easiest way to get pressure in the lines just cranking it over or actually trying to draw it through the system first with some type of pump mechanism? Thank you
