Water somehow getting in rear compartment
I noticed that the rear of my burb has a very wet carpet mostly on ac/heat side, pulled rug on that side and under padding is soaked dripping wet. Thinking it was ac evap drip tube clogged and spilling water to the inside pulled cover and ran ac not leaking there.
Did notice the indents in floor for the back seat mounting were full of water that side (pass/side) removed the drain screws, I'm stumped as to where the water maybe coming in.
Have any of you ever heard of such a leak in burbs?
