Flow rate?
Dont know flow rate but a MileMarker hydro winch works fine w/stock pump "the issue is cooling PS fluid when pump is tasked w/extra work a PS cooler is required" use biggest that fits.
Next issue, high idle circuit makes the hydro winch work much better under all conditions.
Aftermarket high pressure pumps w/remote reservor can be had for just above $300. US.
Visit Flash Off-road and search through tech section for PS issues and mods that apply to 6.2/6.6 diesels.
Reason: link issue remove
