Hi
The snow is moving down the mountains,so i thought i would fantizise about getting my turbo/aftercooler finished
So my questions are about the crossover.I don't have the banks kit,but pieces of it.I havn't seen an acutall banks part.
So far my thoughts were,i fabed up a flange for the banks manifold and the drivers side factory,i used 1/4" T1 steel,have 2 1/4" mandrel bent elbows,originally i was going to use a stainless steel flex section,like you see on most newer car exhuasts, i thought i should have some kind expansion area in the crossover,but have since decided against the flex section because of the inner obstructions and the one on my wifes car burnt out last winter.The flanges i made i was going to bolt tight to the manifolds,so i thought i would need some kind of expansion joint.
So does anyone have a pic of a crossover?
Anyone have experiance making their own crossover?
Any suggestions?
Does it need any expansion area? I Thought about building it in one piece,but am worried about it needing to move with the heat cycles.
I have one from an ats kit that has one end that slides into a little bigger pipe and then was clamped with a muffler clamp,was hoping to make something a little cleaner looking than having a muffler clamp on a crossover
I would like to wrap it with header wrap to keep the heat in and away from the engine.
sorry about the long post.
Thanks Thomas
