So, you're shown to be blowing smoke and you start mocking... I tried to be gentle.Originally Posted by gmctd
This is it's only advantage...not "another" one...as I already stated in my earlier post.Originally Posted by gmctd
I've attached an image of a section of a crankshaft forging for your viewing enjoyment. Notice how the grain follows the contour of the shape. This is what makes a forging stronger than a "billet" piece or a cast piece. This is called "preferential grain flow".
Even if you cold work the piece of billet stock or even if you forge the billet stock into it's bar shape, the machining operations to get the shape of the crank will cut through the grain so that the grain pattern is interrupted. This yields a loss of strength in the finished part.
Bottom line: Make two identically shaped parts (in this case crankshafts), one from a forging and the other from "billet". The forged one will be stronger every time. End of story.
