You Don't Need Lift Or Blocks
I run 285/75/16's under all kinds of conditions w/o lift but trim some.
Frt bumper can be trimmed about 1" at edge of fenderwell, or you can shim it forward w/washers, or short lengths of pipe maybe still use same bolts.
Rear of fenderwell from about mid well height down to rocker needs to be trimmed, or rolled on a taper from zero at mid height rear fender well to about 2" at bottom of rear fender well.
You may have to adjust the above more or less but it works, been running em for some time now.
Back of truck needs nothing to run 285's
Smallest rim for 285's would be 7" which is .50" narrower than recommended width, I use ALCOA 16"x7" all around their capaticy is 3750 lb load rating ea.
Reason: TYPOOOOOOOOOOOOOO
