Everybody's got something so, so, NORMAL...
1. '94 Barth ["What the HELL is that?"] 28' Breakaway Class A motorhome
2. 8500? (I dunno, it has a GVW of 18K lbs.)
3. 4x6
4. 1 (As if there's anything else as an option)
5. 1
6. Injector cleaner and/or ATF only
7. 40
8. Dana 80 4.53 (I think - Mag-Hytec cover installed)
9. 8x19.5
10. Mixed
11. Gear vendor? Nope - no room and unnecessary
12. Boost control: Purely Stock
13. Same as 12.
14. Automatic Trans 4L80E (Mag-HyTec pan installed)
15. Thermostat: 2x195F (Kennedy Diesel kit installed)
16. N/A - DB-2
17. Timing Gear: N
18. Intercooled: N
19. Mist injection: N/A
N20. Air filter: Stock Wix, but this diesel pusher has far less restrictions - "Snorkle" is 4"
21. Non-EGR
22. GM Turbo Style: 5
23. Exhaust: 4" Turbo to ground
24. TDC offset set to : Stock
25. Stock injectors
26. Synthetic oil: N Total waste of money (I'm a former fuels and lube engineer)
27. Highway mileage: 9.8 mpg
28. When mileage data was obtained: Summer
29. Approx miles on vehicle: 52,500
