DOH! DOH! DOH! I just did replace mineOriginally Posted by Big E
Guys, what is the proper way to bleed a diesel fuel system??? Air was getting in from somewhere and I think after four days of searching, have now found and hopfully fixed the leaks (a dogey connection to one of the filters and found a crack in a injector return line. Problem now is that no matter how hard I try, I cannot bleed all the air from the system (unless there is another leak, grrrrrrrr).
If I'm still getting air in, apart from replacing all the fuel lines including the returns, I'm buggered if I know where it is coming from.
attach a vacuum type brake bleeding pump to the output side of the fuel filter, works great if mechanical lift pump, electric-don't know, sure saves beating on your starter motor. still no go-you gotta bleed the lines at the injectors.... with the starter. crack'em all loose a turn or 2 then crank until at least a few or all start weeping fuel then retighten and.................
