Dvldog 3500
1. What model do you drive- Crew cab long box
2. Level- 3500 single rears
3. 4x4
4. Driving Habits; 1 to 5- 4.5
5. Tune of vehicle; 1 to 5- 1.5
6. Fuel additive- Yes, mix of Powerservice, FPPF and two stroke
7. Size of fuel tank- 32
8. Rear Gear Size 4:10 locker Maghytech and sythetic
9. Tire Size 245-75 load E
10. Tread style; Mud/Snow
11. Gear vendor- Yes .78OD, runs in Autodrive all the time (on above 48mph)
12. Boost control; Mechanical NO VAC PUMP
13. Boost pressure setting- MAX is 15psi
14. Automatic Trans w/ maghytech and synthetic fluid
15. Thermostat- Stock
16. PCM programming Heath 2.0,
17. Timing Gear NO
18. Intercoooled Yes
19. Mist injection No
20. Air filter- UNI with air path opend as much as possible`
21. Non EGR:
22. GM8 Turbo
23. Exhaust- Wide open JK 3.5
24. TDC offset set to 1.945
25. High pop injectors
26. Synthetic oil Mobile Delvac
27. Highway mileage- Best observed 22MPG, realistic average- 18-19
28. When mileage data- Summer
29. Approx miles on vehicle: 170,000 (50,000 on new motor)
2001 Chinook RV, V10 gas
1967 GTO, 1989 Honda Transalp
3 kids, 1 wife, 1 dog
