Thread: What's the best synthetic oil to use?
Hybrid View
    Watertown, WI
    I tow 8k to 11k lb trailers about 6,000 miles per year, local and cross-country. What's the best stuff to use?
    [ 08-21-2002: Message edited by: ksevern ]</p>
    Ken Severn<p>K&N, MagnaFlow 4\" SS Exhaust <a href=\"http://webpages.charter.net/ksevern/2500HDcrop.jpg\" target=\"_blank\">Picture</a><p><b>This is why I own a 2500HD D/A CC SB 4x4</b><br /><a href=\"http://www.severnmotorsports.com\" target=\"_blank\">severnmotorsports.com</a>
    columbus, ohio
    There are choices here and you will no doubt get about 322 responses in the next 4 hours on this one...
    I am admittedly quite biased (experiential bias, however) toward the Mobil Delvac 1 5W-40 full synthetic. I work with a number of fleets that run the oil 100,000 miles between changes. Several fleets have every single truck with over 1,000,000 miles and no bearing change-outs and most importantly, no turbo-charger losses.
    Delvac 1 has been around for over 20 years with a proven track record. Flows to 60 below zero yet provides extraordinary protection in 100 degree heat. Good availability,
    Highly recommend doing an oil analysis prior to switching to it for a baseline for use with determining best drain interval.
    George Morrison
    Jul 2002
    Central coast California
    ksevern
    The 2 big dogs in the synthetic oil industry are Mobile 1 Delvac and Amsoil...You will not go wrong with either of these choices...
    As with george morrison I am biased but toward the latter...do some research however stick with 100% synthetic after the breakin period [img]smile.gif[/img]
    \"Skinny pedal to the metal\"<br />2002 chev 2500HD CC D/A S/B BLOOD RED LOADED MACK DADDY<br />Amsoil front to rear <br />Brand new untouched...but soon!!<p>http://syntheticoiltech.com/oil/1/
    Kennedy Guest
    As mentioned above, it's a toss up between Amsoil and Mobil.
    While many have had good luck with the 5w30 Amsoil, I'm a little skeptical. My next analysis with 40w should tell me more.
    May 2001
    Holmen, WI, USA
    I must concur with the choices of Mobil Delvac 1 and Amsoil. I use the 15w-40 Amsoil year round and like it alot. I've heard nothing but good things about 5w-30. But I wouldn't use it unless you are in a constantly colder climate.
    The Delvac 1 may be your best bet though. 'Cause you can get it anywhere. Well, almost anywhere. Moreso than the Amsoil. Not to mention that it is a great oil.
    \'99 2500 ISB QC SLT (No Leather!),4x4,5sp w/McLeod,4:10,BP8x11\'s,B-1,FMS,EZ,PE4200,LPG,H2O/CH4O,4\"exh.,Pac-Brake,OBA,more switches than you,Line-X,V-1,lts,siren,lic. plt. frm says \"<b><i>Diesel Fumes Make Me Horny!</i></b>\",and much more goofy stuff.
