It locks up in 2nd (30+ MPH with go pedal input) and stays locked. It will not unlock until the speed drops below 30 MPH. I bypassed the brake pedal switch, so it will also stay locked with the brakes on. Originally, I installed a toggle switch to allow me to include/exclude the brake switch as desired, but I never liked it unlocking with the brake, so I omitted the brake toggle switch.Originally posted by Ratau:
DmaxMaverick
Do you get auto lock up in 2nd and 3rd ?
With the 10% throttle switch connected does the lock up disengage if you go downhill and you take your foot off the throttle?
Danie
There is no "throttle switch". The tranny gets throttle input from the TV cable, which interacts with the hydraulic circuit of the tranny. Be careful with this. If you try to adjust the TCC parameters with the TV cable, you will throw off all the other shifting characteristics, including shift speeds and line pressures. This could result in too much slippage, and fry your tranny.
I got your email, and sent you the diagrams.
