I'd verify whether the HVAC needs vacuum... If not, I'd ditch the vacuum pump. You can swap in a newer cruise control module and cable assy from a 90's body style gas truck/Suburban to get cruise control functional. Just get the electrical harness pigtail along with the cruise module to make it easier to wire. It'll just need a digital signal from the vehicle speed sensor, power and ground + turn signal stalk switch control.
