Thread: Unable to pull obd1 codes
    Aug 2005
    Default Unable to pull obd1 codes
    It's been a long time now since my last post, like many years I think. Tried to pull codes on my 1995 6.5TD K3500 using the old paper clip method by shorting the top 2 RH pins on the dlc. Dash light will not flash anything at all. How can I check power to the obd1 dlc? Not sure which pin is the 12V. The upper Right?
    Black 95 6.5TD, 929 block, 173k miles, 65k on IP, 48k miles on self-rebuilt engine done in '09, 6 L&S Full-torque inserts in outer main crank holes, Clearwater heads, Fluidamper, rebuilt NV4500, 3" downpipe, 4" exhaust, no cat, dual T-stats, 9 blade fan, spin-on 180 degree clutch, Heath hi-flow water pump and turbomaster, PMD relocated, OPS relay mod, Heath PROM upgrade, and Kennedy headlight harness upgrade soon. Now use semi-syn Lucas 2-cycle oil every fill-up which greatly reduces the frequency of DTC 35-36 codes the PCM/ECM throws.
    Does your "Service Engine Soon" light come on when you first turn the key to the run position? Wondering if the bulb is burned out...
    I just purchased the GMTD Scan software and OBD1 to USB cable for my 1995. It's pretty sweet. I finally got my timing and TDCO set, and was able to read and clear codes. I can even manually illuminate the SES light to make sure it works.
    Aug 2005
    SES light does work, so bulb is OK. But, coincidentally, I just downloaded the basic version of the GMTD software myself. Now waiting on a cable to be delivered from a separate vendor. Hope it works! Thanks for the suggestion.
    Quote Originally Posted by jerry598 View Post
    The GMTD Scan software will make this a moot point, but I'm curious what method you're using to get codes using a paperclip - i.e. key ON.
  1. obd1,software
    By westport70 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-26-2010, 16:19
  2. obd1
    By 3ace in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-03-2010, 11:51
  3. My 6.2L is unable to start
    By bigboy3sa in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-26-2008, 13:39
  4. Unable to set timing
    By jonflies in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-30-2005, 13:58
  5. Unable to stop air flow in back vents
    By A||||1||Robert W. Jones||Diesel Timing Light?||||5||||Stray Cat||00012887 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-05-2003, 21:37
