Originally Posted by
Robyn
I am not sure on towing that rig with the Tcase in N
GM allows flat towing 4WD vehicles with the transmission in Park and the transfer case in neutral. Popular for RVer's to tow 4WD trucks behind their motorhomes for that reason.
