Results 1 to 2 of 2
Thread: Wanted: 6.2 Banks Filter Housing
    Jun 2011
    Snoqualmie, WA
    Default Wanted: 6.2 Banks Filter Housing
    I'm on the hunt for a filter housing for Banks 6.2 Sidewinder kit. I'm looking for the rectangular-shaped filter housing and filter from the kit for the later GM trucks. I have the early style with the triangular filter.
    This is from the later kits, 21007. Housing part number 41032.
    1978 Jeep Wagoneer, 1993 6.2L J-code 599 and a Banks Sidewinder.
    Dec 2003
    Yukon Canada
    That looks very close to the on in the 6.5 turbo equipped GM trucks.
    Maybe get your hands on one of those to see if you can make it work
  1. wanted -- hx35w turbine housing
    By sctrailrider in forum TDP Classified ad forum
    Last Post: 03-08-2013, 05:21
  2. Wanted standard bell housing for 6.5 hd
    By dlg44 in forum TDP Classified ad forum
    Last Post: 02-12-2008, 14:18
  3. (WANTED) Turbo 400 heavy bell housing cover.
    By Robyn in forum TDP Classified ad forum
    Last Post: 12-10-2006, 16:20
  4. Wanted: factory fuel filter housing for 6.5
    By john8662 in forum TDP Classified ad forum
    Last Post: 03-03-2006, 15:32
  5. Help!!! Leaking fuel around filter housing after filter change.
    By 65turboman in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 08-19-2004, 11:32
