Results 1 to 2 of 2
Thread: can I pull the T-stats and run the engine?
    Dec 2005
    Klamath falls/keno Oregon
    Default can I pull the T-stats and run the engine?
    Im cleaning the cooling system and the stuff Im using says to remove the t-stats and run the engine..
    is it going to leak, Im thinking the t-stats are the seals..
    thoughts
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Why are you considering cleaning the cooling system? I've been inside 20 year old Duramax 6600 engines and didn't see any cooling system problems... In fact, the 20 year old Dex-Cool orange coolant still looked pristine and I didn't see any corrosion on the aluminum or cast-iron parts - none. I didn't see a need to service the cooling system.
    Yes, you could run the engine without the t-stats. However, the engine won't reach operating temperature very often (in the winter).
    I tried running Lil Red with its coolant surge tank cap loose... back when its head gaskets were causing a cooling system over-pressure problem. A loose cap caused coolant to leak badly over the inner fender. So, I didn't do that again.
  1. If you were this far would you pull the engine? Is it worth the trouble?
    By j_k_auto in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-07-2007, 22:18
  2. engine pull checklist
    By moody in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-11-2007, 18:02
  3. CAN YOU RUN SYNTHETIC MOBIL 1 IN A NEW ENGINE
    By moedog in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 09-16-2005, 05:00
  4. got my new engine running but it wont run on my computer! Only will run off scanner
    By asabadin in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-26-2005, 20:21
  5. Should I pull engine to R&R lifters? Yes, I believe I should!
    By arveetek in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-14-2005, 12:08
