Results 1 to 18 of 18
Thread: My cost to replace my 6.6
    Dec 2005
    Klamath falls/keno Oregon
    Default My cost to replace my 6.6
    Remanufactured engine inc. freight…… $6300.00
    Gaskets. 238.00
    Acdelco new injectors. 1500.00
    Water pump. 113.00
    Fluids. 225.00
    Labor. 3000.00
    My original engine has 425,000 miles on it, only replaced the turbo, it has a head gasket leak.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Still less expensive than a new truck...
    Or a battery replacement in a cordless vehicle
    How's the body? My '06 was starting to rust when I sold it and that was 9 years go! (To say nothing of the brake and fuel lines I replaced on the way!)
    Dec 2005
    Like the day I bought it, which is why I'm saving it..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Unless you know the rebuilder, a $6300 engine will not be much of an engine. I don't trust any of the big name rebuilders out there. I know Greg from Lube Specialist had 2 or 3 from the one that's about the biggest name in the engine biz that were junk before he went to a smaller more personalized and specialized shop, and even that one he had a few minor issues to work through.
    HG job on yours and should be good to go another round
    For rust I have my own inner panel preferences that can be seen on my FB page, but as a quick annual I'd look at these guys:
    https://profleetcare.com/
    Son in law had his truck done for like $190 but it needs to be re-upped.
    Dec 2005
    $8-10k for head gasket service...on a engine with 425,000.. *gulp*
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    It's a tough call, but think about this for a minute. You expect to get a good reman for less than the cost of doing head gaskets. The head gasket part of the job has to happen for both PLUS pistons, bearings, etc Things just don't add up.
    Dec 2005
    My engine has 425,000 miles, why spend 8-10k for head gaskets then the fuel pump dies, the oil pump dies, oil pressure drops…
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I think JK's point is that a $6300 reman sounds too good to be true...
    Dec 2005
    heres what Im looking at:
    https://shop.powertrainproducts.net/...tdopm09wUvKVbs
    also : https://www.injectorsdirect.com/prod...emanufactured/
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    I wonder what the terms of the warranty are?
    Not sure if I would trust someone who calls them "galley plugs" though...
    Dec 2005
    18 months. because it's a 1 ton truck...3 -7 years for anything else
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Quote Originally Posted by spongebob View Post
    In 2021, I replaced the head gaskets (plus new factory head bolts, fuel system banjo seals, etc) in Lil Red for about $300. I added ARP studs, a new water pump and new injectors to my 2001 GMC head gasket project, also in 2021. That wound up costing about $3300 total, if I remember correctly.
    The mileage that your original engine has wouldn't concern me if it's not been abused. In fact, I'd rather trust it over than the quality of a questionable rebuilt engine. One question I've yet to see answered concerning a Duramax reman is "Did the engine need to be bored?" I've yet to see a cylinder bore on these engines that was worn. The cylinder bores are induction hardened at the factory. Boring them removes the hard layer.
    Dec 2005
    all I know is what they say..and in todays world you cant believe anything..I was thinking when this engine is delivered to look at the cylinder
    walls from under .you should price injectors today some are going for $500 each..I provided a link to the injectors Ill be going with, they are rebuilt by
    Bosch trained techs..fuel lines and glow plugs for $2500 yob got a good deal those days are over.
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    The LB7 reman injectors I installed in my 2001 GMC came from Kennedy - $2200, if I remember correctly, was the cost for 8. I also installed new injector fuel lines at a cost of about $650 and ARP studs for $650 - plus misc consumables. I'd have to dig out the receipts to be accurate on prices, but this is in the ball park. I actually wound up not installing the new water pump, so that cost isn't figured in. I also could have cleaned and re-used the fuel lines if this had been a budget squeaker - saving another $650.
    I re-used the injectors and injector fuel lines when I did Lil Red, because the engine only had about 8,000 miles on it. Lil Red's heads didn't need to be decked, and I installed factory head bolts when it went back together instead of ARP - that saved $500. Glow plugs can be tested before they're re-installed. No need to replace them if they're still in good shape.
    Dec 2005
    Im at around $12k for it all,,Chevy wants $10k just to replace the head gaskets..there doesnt seem to be alot of chatter on guys with older duramaxs
    rebuilding or saying what the bottom end looks like with 400+k on the clocks
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    751,837 Mile Duramax - A 2005 GMC Goes the Distance
    https://www.thedieselpage.com/duramax/750kduramaxc.htm
    More here: https://www.thedieselpageforums.com/...d.php?p=267823
    Too bad you didn't live next door. I'd help you with whatever you decide to do.
  1. cost to rebuild
    By rickm in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 03-12-2008, 22:39
  2. Overhaul Cost?
    By Chris Strandt in forum Duramax 6600
    Last Post: 03-30-2005, 09:58
  3. GM cost cutting?
    By Kennedy in forum Duramax 6600
    Last Post: 04-02-2004, 10:23
  4. Transynd Cost
    By Dmaxducker in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-31-2003, 19:34
  5. GM Cost Cutting on '03's
    By andy911 in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 08-29-2002, 22:09
