Thread: 84 gmc 2500 g20 6.2
Hybrid View
    Dec 2023
    Ma
    Default 84 gmc 2500 g20 6.2
    After cycling the glow plugs Multiple times when cold (48 degrees) the van will not start. If I plug in the block warmer it starts Automatically
    I have 12 + volts to the relay at the back of the driverside cylinder head but only 9 1/2 volts out to the glow plugs all 8 glow plugs have power to them but only 9 1/2 volts is that my problem? Any info would be appreciated
    Test your glow plugs to see if they are any good
    Dec 2023
    Ma
    I will be checking them. I was told they were just put in not even 2000 miles ago.
    But that doesn't mean anything he did use ac delco Ty
    Welcome aboard!
    12V in and 9.5V out of a relay is a bad contact. It should carry full voltage. If that's the fact, there's too little juice to heat the plugs enough for a solo start. Easy starting with the block heater almost certainly confirms that.
    Your other thread in the Photo Forum, stating essentially the same as this thread, will be deleted.
    Dec 2023
    Ma
    Thank you. I cleaned up some rusted connections and will be checking.
    To see if I have more voltage coming out of the relay I actually did not check the voltage. Because I got it running on a cold start with no plug in. Hopefully I fixed the problem. Ty
  1. 95 gmc 2500 Parts
    By rclippard in forum TDP Classified ad forum
    Last Post: 12-18-2009, 17:38
  2. New Here and I have a 1983 GMC 2500 6.2L
    By -Greg- in forum Photo Forum
    Last Post: 11-02-2007, 06:12
  3. GMC 2500 HD vs GMC 3500
    By Harleyfl in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 07-30-2007, 12:06
  4. rims for GMC 2500 HD
    By fourtenposi in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 10-02-2005, 16:02
