Results 1 to 9 of 9
Thread: RV Trailer question
    Quote Originally Posted by FKummert View Post
    I would like to make a little comment, it is not good to run pumps dry, it will shorten the life of the impeller.
    RV fresh water pumps are cam-driven diaphragm type. No impeller, and can be run dry indefinitely. They have no moving parts within water/liquid contact.
    That is correct!
    https://www.pentair.com/en-us/produc...ntair_products
    "Can run dry without damage."
    Mar 2015
    Montana, the warm state.
    I stand corrected, but my old camper has a pump with impeller.
    Part of the fleet.
    85 Sub. 6.2 trans out.
    82 3/4 CC 6.5 N/A
    83 GMC 1 Ton 6.2 Est Mil. 1 MIL +
    96 Dodge 3500 5.9 4X4 Sorry, went to the dark side.
    19 Escalade Buick
  1. Another Trailer Tire Question
    By TJ Moose in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 07-22-2005, 15:15
  2. Another Trailer Tire Question
    Last Post: 07-19-2005, 20:35
  3. Trailer Tire Question
    By Roy W in forum Towing - 5th-Wheels & Travel-Trailers
    Last Post: 07-18-2005, 08:05
  4. Trailer adapter question
    By Manfred in forum 2500HD/3500 Accessories
    Last Post: 05-16-2005, 05:11
  5. Quick trailer question.
    By hoot in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-23-2002, 20:19
