Originally Posted by
DmaxMaverick
RV fresh water pumps are cam-driven diaphragm type. No impeller, and can be run dry indefinitely. They have no moving parts within water/liquid contact.
That is correct!
https://www.pentair.com/en-us/produc...ntair_products
"Can run dry without damage."
