Results 1 to 7 of 7
Thread: Water in pan after a week of sitting with no prior issues
    Aug 2023
    United States, Oregon
    Default Water in pan after a week of sitting with no prior issues
    Hello,
    Vehicle 1989 K2500 6.2L J code.
    So I have water in my oil pan suddenly. I parked my car for a week to remove 8 swollen plugs. Prior to this I had driven the car up and down the road and took it for one long drive to move it from one property to another (>30 miles highway driving). It also sat in a field for over a decade without any water getting into the oil. I haven't had any issues with water in the oil.
    I haven't had any overheating issues. Although I haven't taken it for a drive yet. I haven't done a compression test. Just based on cranking there is an even gallop and the engine sounds healthy, I am in the process of moving so I can't find any of my tools, I will be renting a diesel compression tester this weekend. There is a good bit of milk shake. I change the oil once and when I started running the engine again I got milk shake again. I still haven't driven anywhere just idle the car.
    I don't have the belt hooked up and the water pump pulley is off. I have just been idling it for short periods of time.
    I did wash down the entire under hood interior with a garden hose, I wouldn't expect to make it passed the rings, I wasn't sure if there was another entry point? There is the back of the engine where a distributor is on a gas engine, where I understand a mechanical vacuum pump is driven?
    It has all of the symptoms of a head gasket, but it just doesn't make sense to me how it could be. I want to be certain before I tear the heads off.
    I have lost a significant amount of coolant during the glow plug removal but I also disconnect the heater core to get the back plug / injector and I just let the hoses dangle and the coolant drain during the process.
    I also had to remove a bunch of things and put them back such as the dip stick. Although I believe as of (after) last time I change the oil, it is secured with the 7mm bolt into place. During the week while it was sitting the dip stick pulled out and it was raining consistently, heavily, every day. The vehicle is parked outside, not covered.
    That's a LOT of variables that certainly could explain water/coolant in the pan. A failed head gasket is possible, but with so many other more likely possibilities, hold that thought. I suggest a coolant pressure test (before an unnecessary compression test), and allow it to set under pressure for several hours. Drain the oil and leave it open, with a drain pan below. Watch it for any coolant draining while it's under pressure.
    Aug 2023
    Default Update - Cooling system pressure test + oil filter change
    Ok, I did this. I couldn't let it set for hours because I have a coolant leak that I was someone aware of at the lower radiator hose. I have cheapish eBay aluminum radiator and the OEM size hose doesn't match up with the outlet hose with the radiator. It was the closet thing I could find on eBay for $200. I kept it pressurized for maybe 10 minutes nothing drained from the oil pan except for oil.
    I did change the oil (again) and the filter this time. I ran the car for maybe a minute and it looks like there is already a significant brown milky oil / water mixture already.
    More variables. Where is the oil cooler plumbed?
    That leaves only a cylinder leak-down test. Compression tests are helpful for other things, but essentially useless for identifying small cylinder leaks.
    I doubt you'll find a head gasket failure, on this one. More likely, cylinder head or block crack.
    Aug 2023
    So this symptom randomly appeared. I have been working on this truck for 6 months and it randomly appeared over last couple weeks. Why would the head or block crack now? It sat in a field for 10 years and when I got the truck the radiator was plum full of coolant. I did pull 8 swollen glow plugs out of the head recently.
    I ran the truck for an 30-45 minutes and the oil fill cap off. I was periodically checking and the water/oil milkshake mixture slowly disappeared. This was a few hours ago and now the engine has cooled down and there appears to be no water / oil mixture visible to the eye on the dip stick. There is still some water in the engine, I found some condensation on the oil filler cap which I placed back on the oil fill tube a 10 minutes after shutting off the engine. I just check just the oil fill cap a few minutes ago (that is when I found the condensation)
    Feb 2012
    Pauline, SC
    Head studs or stock tty bolts?
    Could it be possible that the loose heater hose drained coolant into the open hole after removing the injector/plug?
  1. Oil Pan to Block and Pan to Timing cover bolt thread pitch?
    By john8662 in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-10-2011, 20:17
  2. Allison no go after sitting a week
    By Sneaks in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 06-06-2003, 16:39
  3. Bike Week-Water Week Trip report,MPG,etc
    By Paintdude in forum Duramax 6600
    Last Post: 03-12-2003, 07:49
