Thread: A/C compressor and fan wiring diagram
    Aug 2016
    Waco, TX
    Default A/C compressor and fan wiring diagram
    Does anyone happen to have a wiring diagram for wiring up the compressor and the fan in front of the radiator. This is all factory wiring, its on a 1983 C10 6.2 diesel. I haven't been able to find anything on this. Any help is appreciated. rudyj
    Hi
    I don't think the fan in front of the rad is original,i have never seen one like that or heard of anyone having an OEM fan in fronty of the rad.
    As for the AC there should only be 2 wires going to the AC clutch
    No square body trucks came from the factory with an electric fan in front of the radiator. They only used the engine-driven fan.
    Aug 2016
    Waco, TX
    Thanks for the replies.I got it all figured out. I now have A/C. RudyJ
  1. A/C Condenser Fan wiring diagram
    By coxfmly in forum 1982-2000 C/K Truck & SUV Chassis & Drivetrain
    Last Post: 10-16-2015, 05:32
  2. Wiring Diagram
    By akarpf in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-07-2009, 11:57
  3. Need 6.2l a/c wiring diagram
    By phifer8390 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 10-20-2008, 15:44
  4. wiring diagram
    By colorsink in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 02-17-2007, 14:34
