Thread: wanting to remove the headliner material
    Dec 2005
    Klamath falls/keno Oregon
    Default wanting to remove the headliner material
    mine has the famous air pockets and coming apart
    on the edges..what am I in for if I pull this material off?
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    Extended cab models are easiest to replace the complete headliner. Other models require windshield removal. It's just fabric glued to a board, so what you see will be what you get.
    Dec 2005
    I’m not wanting to take it all out , just the fabric..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
    If you just want to remove the fabric and leave it bare, just do that. Cut away the parts that have let loose, or remove all of it. The fiber board and remaining adhesive will be what's left where the fabric is removed. It won't look pretty. If recovering or replacing it, it needs to come out, which isn't difficult at all in an extended cab (barn doors, with no B pillar in the way). If you want to make it somewhat presentable, you can remove it, strip it of all the fabric and adhesive, then paint it. I've seen some textured coatings that blend right in and look nice, if noticeable at all (some manufacturers actually do this instead of using a fabric covering).
    Dec 2005
    Tex’s.. I’ll do it..
    Hummer wheels :^)
    dual lift pump
    Banks air intake
  1. Desperately Wanting Duramax/Allison 1500
    By afgunn in forum Diesel Conversions
    Last Post: 09-30-2012, 21:08
  2. Trailer Decking Material Question.
    By Jim Cobler in forum 2500HD/3500 Accessories
    Last Post: 07-03-2004, 14:54
  3. duramax not wanting to start
    By elevatorman in forum Duramax 6600
    Last Post: 02-07-2004, 14:28
