Thread: Single Mass Flywheel for 6.2L/6.5L Diesel
Hybrid View
    Thumbs up Single Mass Flywheel for 6.2L/6.5L Diesel
    I've been corresponding with a 6.2L diesel owner over a couple of weeks about the flywheel situation for the manual transmissions. Here is his most recent message, which I thought might help any others who may need these parts.
    Hello, Jim.
    Thought I would follow up with you on the solid mass flywheel on a 6.2 Diesel.
    I finally contacted a vendor who really knows his stuff. Knows about the GM service Bulletins on them etc.
    I talked to Lou at Phoenix Friction in New Jersey. They have a kit for the job with flywheel, clutch, bearing and bolts for $500 including shipping. I will update you on how well it works when the job is finished. Blessings.
    Al Peterson
    Web page: https://www.phoenixfriction.com/p-23224-04-163ck-solid-flywheel-conversion-clutch-kit-gm-65l-diesel-pickups-suvs-12-in.aspx
    Feb 2012
    Pauline, SC
    Good luck, I purchased a kit from them a few years ago for a customer, I had his motor here building it and took the flywheel along to have during the crank balancing process... the shop called and said their was a big problem, the flywheel was very very out of balance. I took it home and compared it to the one that came off the motor when I tore everything down... the holes drilled to balance it along with the large chunk cast in the wheel was in the wrong place by 90* .... they are china made and machined and somehow the crank bolt holes were miss located... Lucky I used paypal because they said nothing was wrong and it would be alright.. paypal ended up giving my money back after I sent in pics...
    1993 Chevy K3500
    like us on Facebook
    Good information!
    Thumbs up Followup from Al - Oct 2, 2023
    Followup from Al --
    Hi, Jim.
    I realized that I never updated you on the flywheel replacement.
    I had a local shop do the job for me since with my medical issues crawling under vehicles without a lift is no fun at all.
    He also replace the rear main seal. It took a long time for him to get it done but I was not in huge rush. No issues just not a priority for him.
    I got it back and took it for a drive. It seems to me to be smoother than it ever was before when releasing the clutch. It always seemed a bit grabby to me with the dual mass flywheel.
    So,I would recommend this kit from Phoenix Friction. I think all in it cost me about $1400 Canadian.
    Have a great weekend.
    Al
  1. Dual Mass Flywheel again?
    By crafty in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 02-01-2011, 19:29
  2. Can anyone tell me if this is the single mass flywheel?
    By Ggerg1186 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 04-20-2010, 06:42
  3. Any way to check if a truck has a dual-mass flywheel or the solid flywheel??
    By XPLRN in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-11-2007, 23:49
  4. single mass flywheel 125.00
    By Alf in forum TDP Classified ad forum
    Last Post: 08-14-2005, 15:13
  5. Dual Mass Flyweheel vs. Single Mass
    By BuffaloGuy in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-29-2003, 17:57
