The above repair order was created May 17, 2021 by our local GM dealership. I had requested a quotation for replacing the Duramax head gaskets in my 2001 GMC. This was my first contact with them about this proposed project. You can see that their shop rate was $139.00/hour. Let that soak in a bit as you prepare for discovering just how many hours it takes to R&R the head gaskets on a Duramax 6600.
The following quote fleshes out the parts and labor costs to perform a head gasket replacement by our local GM dealership. It's breathtaking...
Now, I like and trust this particular dealership. I've known their lead diesel mechanic for more than 14 years. He is a Duramax enthusiast, who has been inside these engines enough to be very good at it. But still.... $2,232.44 in parts and $4,948.40 in labor, for a total of $7,310.84... This does not include anything other than new head gaskets, new head bolts, cylinder head decking, miscellaneous fluids and hoses/seals/sealants, and 36 hours of shop rate labor.
For my 2001 GMC, I was able to replace the head gaskets in my own shop using new gaskets, 8 new SAC injectors, 8 new injector fuel lines, new ARP head studs, cylinder head decking and a range of other smaller items for about $3500.
Replacing the head gaskets in Lil Red's Duramax 6600 using just new gaskets and new factory head bolts cost me only about $300.00 - a tiny amount compared to the dealer quote.
As of 6/2023, the GMC had accumulated approximately 11,000 miles since getting new head gaskets and injectors. Lil Red has accumulated more than 4,000 miles since replacing its head gaskets. Both continue to run and drive as well as when each of their Duramax 6600 engines were new. The head gasket replacements, injector service, injector cup service, valve train adjustment, and all the rest have been completely successful.
$7,000+ should be incentive enough for nearly every Duramax owner to do this work themselves. It's not that difficult with the right information. You can get the right information, our Duramax Service Guide (see link below), for the cost of just over a half hour of shop rate labor. Let us help you do the best job possible and for the lowest cost.
