Page 5 of 5 FirstFirst 12345
Results 81 to 93 of 93
Thread: 6.2 Redblock Theory
  1. #81
    Jul 2020
    Interesting metallurgy patent info.
    https://www.govinfo.gov/content/pkg/...1a37c149b8.pdf
    General Motors has more Patents then I care to read lol!
    https://patents.justia.com/company/g...-motors?page=3
    A reputable company that deals with US patents I will call and ask some GM questions.
    https://www.candcip.com/metallurgy
  2. #82
    Recycled steel and various other metals can be used to make a myriad of products.
    Cast iron is a more generic term
    There are many types of cast-iron alloys, but the four primary categories include white cast-iron, gray cast-iron, ductile cast iron, and malleable cast-iron.
    In order to get a consistent "Batch" at the foundry the materials have to be a well managed blend of several given substances.....
    Bumpers off a few Toyota pickup's, a handful of rail road track and sundry cast brackets from ancient tractors is not gonna cut it...
    Repeatable mixtures of the required elements in huge quantity are required.
    I do believe most recycled materials are used for more mundane items.....A batch of fenders made from scrap car bodies.....VERY POSSIBLE
    We have an outfit locally that takes in huge quantities of scrap steel....They turn out rebar and steel T posts (The green/white fence posts)
    They ship out huge rolls of rebar every day...
    Steel sheets and such can be made from a lot of recycled materials.....
    Engine blocks have to be a bit tighter on the mix...Steel fenders can't be made into cast iron....
    MY OTHER POST ABOUT WHAT WAS USED WAS A BIT OF TONGUE IN CHEEK..
  3. #83
    Jul 2020
    Ok cool! I was feeding your excitement :-)
  4. #84
    Yup.....:d:d
  5. #85
    Jul 2020
    The owner of Twisted Steel Performance most graciously donated a lot of P400 block material for my metallurgy experiment lab testing. Definitely more then 5 grams! Thank you soooo much man!
    Here’s the block identification.
    The drill sample location:
    The material in the test tube:
    I only have 2 more blocks I need to get material for before I send the samples to the lab for testing. Soooo exciting!
  6. #86
    Which blocks are on your hit list?
  7. #87
    Jul 2020
    When my blazer is out of the shop, I’ll get a sample from its Optimizer and a sample from customers 85 6.2 block after I pull it. Just progress is slow because parts are on back order.
  8. #88
    Just scored a free 599 engine complete
    Is it one that you wanted to test?Attachment 6631
  9. #89
  10. #90
    Jul 2020
    No. I’m good! Think I have all I need here soon. Don’t wanna pay more then $1200 on tests lol. What are your plans for that 99?
  11. #91
    Pull it apart soon to see what is savable.
    It was sitting out in the weather for quite a while,water was leaking out when i winched it up my rollback.
    I hope i can salvage more than the injection system.
    Hopefully the block and crank are salvageable.A bore job will probably be called for.
  12. #92
    Jul 2020
    Just an update. Still waiting on more samples. Should have what I need after I am done building an Optimizer.
  13. #93
    Hi
    Good to see you again
    Merry xmas
    I have another 599 block in my shop to try and save
    Came out of the 94 i am dismantaling
  1. 82 Redblock 6.2 coarse thread heads
    By Vin82k3500 in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 07-26-2013, 18:23
  2. Another crank failure theory .... oil temperature
    By Hubert in forum 6.5L Turbo Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-10-2008, 16:51
  3. Injector/Fuel Flow Theory?
    By FWBennett in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 11-18-2004, 14:36
  4. Aeroturbo muffler and vortex theory
    By morgan in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 05-14-2004, 17:32
