Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 101 to 120 of 199
Thread: 6.5L Turbo Diesel Blazer Project
  1. #101
    The rear glass may have been replaced on the cheap, omitting the heater grid, or it may not have been available at the time of replacement. Other connectors may be for closure switch, power lock, or lighting (CHMSL, courtesy, license plate). My 2001 has a wire/connector at each end of the rear glass for the heater, which seems silly (should be a single harness and connector, but they didn't ask me). I also replaced the HVAC control head to add the "Rear" option for heated mirrors. Mine wasn't originally equipped with rear defog or heated mirrors. When I replaced the rear glass years later, I added the defog option (the harness connectors were there). The GMT-400 models may be similar, in that the HVAC control can be swapped with or without the "Rear" option. It's possible your control was replaced with the option, never having the rear defog glass option.
  2. #102
    Their power tools are pretty decent.
    Wrenches are good.
    I bought an air compressor from HF after my 30 plus year old unit came apart one day...
    It started sounding odd....By the time I got into the shop it was shedding pieces...BIG ONES...
    I bought one of their decent power compound sliding miter saws earlier this year - I have a cabinet type project to complete. The saw is easy to set up and the quality seems to be pretty good - certainly adequate for anything I'll need. It makes nice true cuts - I like it. Wish it was made in North America, but not much of anything is anymore...
  3. #103
    The Center High Mounted Stop Light is there and works as advertised.
    It seems odd to me that the struts themselves would be used as part of an electrical circuit - since both ends of each strut has an electrical connector like the one shown in the photo. Everything appears to work except for the rear defog, but there is no grid in the glass and no lose connections anywhere that would connect to a glass grid heater. Unless there's a duct that takes defroster air to the rear... I agree with you... till I learn otherwise, that the switch on the dash may have been swapped in when the option wasn't in the vehicle. Maybe I could check the RPO codes in the glove box...
  4. #104
    It's for rear defog, whether the glass is right or not. Many replacement parts specify it. I think it's likely the rear glass has been replaced without the heater grid option. When I replaced the rear glass on my 2001 the price was the same for either, but it may have been significantly different for the Blazer glass, or it could have been an availability vs. necessity issue.
  5. #105
    I have the same type of saw....Earlier one ....Mine is not the Bauer brand....
    I think mine is the Chicago Electric
    Been a great saw...
    They are all copies of the various name brand saws.
    Buddy of mine who is a carpentry contractor stocks his work Vans with HF tools.
    Only his long time workers get the good stuff.
    If the person takes good care of the cheap crap....then they will move up to a newer van and better tools.
    I used mine when I installed the Pergo floor in the dining room/living room.
    Great for cutting the moldings at the floor.
    I have used it for a few other jobs...Son in law borrowed it a few times until missy bought him one for Christmas.
    I tried one of the 18 volt drills.....Garbage.....I also have a Ryobi ONE PLUS batch of tools...and some Rigid 18 volt stuff
    Bought a huge bag of Ryobi one plus tools at a garage sale CHEAP...... Did not even look like they had been used.
    I think I have accumulated 3 of the little small circular saws....
    Got at least 5 or six chargers for the LI batteries.
    The 18 volt 1/2" impact wrenches are so so.....Good for driving lag bolts and some stuff.
    I used mine a lot on the cat....Easy to run down bolts and such....
    Can't beat air tools.
    I have a 1/2" HF air impact that just won't die....Secret....Keep oil in them...
    I used my 3/8 right angle air wrench on the rear diffy job on the van this weekend.....
    Harbor Freight....A toy store for grown ups.
  6. #106
    The Blazer was made legal so it can be driven on the street. The woman at the DMV couldn't understand, at first, why it hadn't been licensed since 2009...
    I also got the brakes sorted out, so it's safe - for now. Then I took it out on the highway for a real test... I found that the Turbomaster is set to produce a max of 12-psi of boost pressure, and it'll stay there for as long as you're into the acc pedal. No codes popped up, so the programming must be OK with it. That may have been part of the problem with melted pistons... the GM-4 turbocharger really needs an intercooler when pushed to 12-psi (the GM-series of turbos are not that efficient past about 7-psi - the boosted air gets hotter), and combined with more fueling than stock. Runs great though. All of the gauges work correctly and there are no warning lights on the dash.
  7. #107
    Sweeeeeeeeeeeeeeeet.
    Good to hear.....
    I think I would back the TM off a bit and get it down to about 8 psi.
    That should keep the kid from having any issues.....
  8. #108
    Thumbs up
    Well, with most of the mechanical issues dealt with, it was time to drive it! Here, daughter is behind the wheel on one of our secondary roads, though she had it up to 75 on a 4-lane highway near here. The 6.5 does a great job!
    We even took the Blazer out for a drive later that night, to do a little night driving. All of the lights work.
  9. #109
    Absolutely Marvelous
    So happy to see the rig back doing what it was meant to do.
    I am certain that your daughter is tickled pink too....Especially after having her hands in the job.....
  10. #110
    Feb 2006
    Miami, FL
    Good work by you and your daughter. Almost typed her name, but perhaps she likes a low profile.
    Gauge pods on the A-pillar is a nice touch.
    Dr. Lee
    1984 C-10, custom 6.5L SAA, custom 700R4, Gone but NOT FORGOTTEN
  11. #111
    Smile
    Sarah, my daughter is here for a few days... Christmas and all. She got a few gifts for her Blazer... I'll be showing you all some of them soon, because I like them and had planned on getting them for myself... Husky Liner floor mats are one such item. I'd looked for these quite some time ago, but couldn't find them, even their web site didn't list them. But, I finally found a retailer that had their mats for the GMT-400 trucks, which are designed just like those I've had for my 2001 GMC for nearly 20 years. I love them. They trap water (and slushy snow soaked with road de-icer) before it can run onto the carpet. I also got her a set of mud flaps from Husky Liner as well. These are molded to fit the contour of the GMT-400 front fender flairs. They look great, better than the flat slabs I've used before... I'll show these items in an upcoming piece. And I got her some repair/replace items and a couple other parts. Who'd a guessed a girl would be fun to shop for? (Actually, she's always gotten guy type gifts from me in past years.) She's happy!
    Merry Christmas All...
  12. #112
    Sweeeeeeeeeeeeeeeeeet....Just does not get much better than this....
  13. #113
    Smile Sledding
    Was a beautiful day today... for the last week in January, so I thought I'd take daughter's Blazer out for a little run.
    It hadn't been started for well over a month, but it fired right up. Daughter hasn't taken it home yet because there are some upgrades we need to complete... Steps... Mudflaps... and the planned bed-liner application on the rockers, grille, fender flares, mirrors, etc. plus drive it enough around here to make sure its reliable. I'd also like to replace some of the steering/suspension parts to tighten up the handling. All this is more of a spring project... hopefully.
    Over Christmas, we installed new Husky Liner floor mats (front and rear) and new rear hatch struts.
  14. #114
    Looking good, Jim!!
    Can't wait to get mine back on the road. I currently have the transmission out, getting ready to swap in a new torque converter (again). Third time's a charm, right?
  15. #115
    Looks Good Jim
    I always wanted a 2 door Blazer/Tahoe...but could never find a diesel.....at least not in acceptable condition....They were either total roaches or waaaaaaaaaaaaaay too $$$$$$$$$$$$.
    Casey......Check the new converter and make real sure it runs true before you stuff it in....
  16. #116
    Any suggestions on how to do that?
  17. #117
    If you can get access to a lathe that can swing the converter (A 3 jaw chuck)
    Insert the hub (Part that goes into the trans) into the chuck and gently snug the jaws.
    Rotate the converter and check the pilot for runout (.001-.004 max) (Pilot goes into the crank shaft)
    Also check for runout at the pads where the converter bolts to the flex plate.
    Generally the pilot does not wear or get replaced....so a look see at the pilot for runout should do fine.
    The hub can get worn badly, hence the reason they get replaced.....
    Having been through this same debacle a few times.....I will never replace a converter without checking them for runout....
  18. #118
    Thanks for the info! Unfortunately, I don't know anybody with that kind of equipment. I've already started filling the new converter with fluid. I guess I'll cross my fingers and toss her in and hope for the best!
  19. #119
    Looks Good Jim
    I always wanted a 2 door Blazer/Tahoe...but could never find a diesel.....at least not in acceptable condition....They were either total roaches or waaaaaaaaaaaaaay too $$$$$$$$$$$$...clip.
    I haven't seen a 2-door diesel Blazer/Tahoe on the highway in years. They have always been rare - now even more so because of the time involved. Twist of fate, maybe... but, the engine failure may have actually extended this one's life. If the engine hadn't failed, I doubt I would have gotten it back. Plus, sitting for about 12 years - mostly in a garage, extended its life too. There's no body rust, and it had been taken care of pretty well by its previous owner, as evidenced by the sometimes excessive accumulation of grease around every grease fitting. The sticker on the windshield showed just a few miles had passed since it had been serviced. It's a peach.
    At 187K miles, there's a little play in the steering wheel, so it'll likely get new tie rods, idler and Pittman arm this spring. I'll be doing this for Lil Red too, so it'll be a party...
    Still fussing over good looking steps... Can't find any we like that are made for the GMT-400 trucks, including ones like those I put on our 6.5TD Project truck back in 1999 - which I really liked. I did find a new design that looks tough, but they don't make them for the older rigs...
    https://www.carid.com/raptor-series/...specifications
    I'll have to modify them to get them mounted... but... I did get a welder for Christmas...
  20. #120
    I've been watching the board for the return of your Tahoe. You know, other than paying attention to the stall speed of the TC, I've not worried about them. Keep us posted on progress.
  1. 85 k5 blazer 6.2 turbo conversion
    By jasonh in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-18-2017, 10:33
  2. Cucv Blazer Turbo 400 same as Civilian
    By darkroad in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 01-22-2007, 19:55
  3. My 6.2L turbo project update
    By arveetek in forum 6.2L Diesel - Tech Support - Troubleshooting - Performance
    Last Post: 06-29-2004, 13:37
  4. How about a Twin Turbo 6.5 in a 73-74 Blazer?
    By Uncle Wally in forum 6.2L/6.5L Diesel - Upgrades & Service Questions Answered
    Last Post: 03-06-2004, 15:08
