Originally Posted by
More Power
I like your swing-away spare mount a lot, and a swing-away was our first consideration. Then, Sarah looked at some of the commercially available ones. The nice ones are out of reach in price (between $1k-$2k), and to be honest I have enough projects this summer to think about fabbing one... In fact, I didn't think far enough ahead on the steps I'm installing now... It's taken about 3 days to complete the fab/prep work. The hitch mount for the spare was just $100 delivered.
By the way Casey, what do you do about the rear license plate? I'm thinking about either fabbing or buying a relocation plate holder for Sarah.
Yes, commercially available bumpers/tire carriers are stupid expensive. I don't have a lot of money tied up in my carrier, but probably 4 or 5 days of fabrication time.
My license plate is in the stock location. The tire is up and to the right, and doesn't block the plate when viewed from straight behind.
