Originally Posted by
DmaxMaverick
Identify which side is the trouble, strip the top/front of the engine down (remove accessories, turbo (if passenger side issue), intake, pumps, etc.), and remove that head. See what you have to deal with.
That is exactly my plan. I want to discover what the issue is, and THEN step back and form a game plan.
