I've mentioned here before that Youtube can be a fun place to hang out or learn something you didn't know. However, when it comes to working on your Duramax 6600, a little common sense can go a long way. Back in 2021, I did a search on YT about Duramax 6600 head gasket replacements... I found the most popular video in the list of those I watched to be one where the mechanic was using a horrible technique to prepare the block deck for new gaskets... Here's a screen grab. Yikes!
The above image would be appropriate if he was grinding off a half inch of body filler - but this is not appropriate prep for new head gaskets. To compound the problem, there is absolutely no attempt to prevent carborundum grinding grit and debris from falling into the lifter galley, onto the piston crowns or into the cooling passages. This is NOT how GM specifies the heads and block decks are to be prepared...
The next image shows what IS recommended by GM - to help prepare the Duramax 6600 head and block deck surfaces.
This is a 3"x4" steel block that was machined flat on a milling machine. GM recommends using a light oil (I used WD-40) with 600-grit wet/dry paper on the pictured steel block to prepare the cast iron block and aluminum head deck surfaces. I also stuffed the lifter galleys and piston crowns with clean shop rags, and any accumulating oily sludge was prevented from entering the cooling passages. Our Service Guide linked-to below shows how this is done.
The Duramax 6600 head gaskets require a certain smoothness for both the block and head deck surfaces. The design of the head gaskets require this smoothness, and the differing temperature coefficient of expansion between the aluminum heads and cast-iron block demands it. 600-grit provides that smoothness, when used with an absolutely flat steel block.
I had a local fabricator make this block for me, but you could create your own by using a 4" length of 3" steel angle iron. Then make it flat by using a series of coarse/fine grit wet/dry sand paper sheets on glass or a flat counter top. Round the edges before completing the job - so they can't dig into the aluminum heads.
The job of preparing the heads and block isn't that difficult and it goes pretty fast. Jim
