Results 1 to 2 of 2
Thread: Lower shock absorber conversion
    Jun 2020
    Seattle
    Default Lower shock absorber conversion
    Has anyone made a conversion bolt assembly for the shocks on the 1994 trucks? I want to use the single horizontal large bolt mount shocks on my truck when it came with the two vertical bolt system on the bottom mounts. The top mount is the double pancake model from the factory and my spare shocks share the same top mount.
    I'm sure someone has done it, but I've not heard or seen. If you're dead-set on it, you'll probably need to weld the late model brackets to the axle, or onto the existing brackets. I have a dead 1995 axle here (somewhere), and I could cut off and send the brackets to you. It's a 10-bolt from a K1500. Maybe try looking locally, first.
  1. C4500 shock shock
    By Mark Rinker in forum GM Medium-Duty
    Last Post: 01-04-2009, 18:17
  2. Shock absorber question
    Last Post: 05-11-2005, 11:53
  3. steering shock absorber
    By William Lee Gingerich in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 01-04-2005, 10:31
  4. Shock absorber bolt torque?
    By ColoradoSpringsToDaMAX in forum 2500HD/3500 Accessories
    Last Post: 08-03-2003, 00:01
  5. The REAL Shock Post of all Shock posts.
    By Alli-max in forum 2500HD/3500 HD Trucks & Drivetrain
    Last Post: 05-29-2002, 20:29
